Need Help Wiring Backup Camera T@B 400
Ontheroadwithdog
Ontheroadwithdog Member Posts: 2
Anyone have a little experience accessing wiring behind the bed .   I want to tie in a backup camera on my 2024 T@B 400
thanks
    qhumberd Administrator, Moderator Posts: 900
    Welcome @Ontheroadwithdog and we have lots of members with experience. And feel free to do a search if you have some time to look thru the threads.
  • Ontheroadwithdog
    I have no idea how to use the forum so thanks for patience
    edited August 2025
    So no worries @Ontheroadwithdog
    It’s a learning curve when you join, and way too much information at once.
    First, the title of your new Discussion helps folks find what you are needing help doing
    Changing that to “Need Help Wiring Backup Camera T@B 400” and post to the right category (Battery/Electrical & Solar)
    As for searching, the Search Icon upper R pulls all the threads that may or may not help
    For example, I typed “wiring backup camera T@B 400”
    The list of links with the number in each can help you scan.
    This one was a few down and has a detailed description of using the wiring of the license plate and it’s route back into the camper, so try that to see if it’s what you need
    https://tab-rv.vanillacommunity.com/discussion/12601/2021-nucamp-t-b-400-boondock-installing-rear-view-wifi-camera
