Hi folks,
Cirrus 620 here with Battle Born lithium upgrade. I noted in the 620 manual that the truck will recharge the house battery while underway in the non-upgraded battery setup. Does it also do so in the BB upgrade? If so where can I monitor input while my truck is running?
Thanks in advance!
0 ·
With it turned off, I'm now getting 14.4 at the battery while it's running. I haven't had a chance to draw down the battery and go for a drive yet to see how many amps per hour I'm putting back in, but due to the small wires in the trailer plug, I'm only expecting 4-5 amps at best.
Disabling the BMS does have it's own drawbacks as far as remote start, and automatic updates. Upside is truck battery gets a full charge, and the smart systems don't drain the battery while it's parked, which is most of the time.
2022 Ford F350 Tremor | 2022 Cirrus 620
