T@B 320CS-S for sale - $15,800 OBO
MickerlyMickerly Member Posts: 472
2018 T@B 320CS-S for sale by owner in Fort Worth, Texas. Absolutely the best “camping” trailer ever. It’s time for someone else to enjoy this gem. Everything looks like new. We are preparing to retire and this wonderful camper needs a new home.
Maintenance:
  • New flooring: A NuCamp flooring recall. Plywood under floor was inspected, the section under the kitchen was replaced with Asdel. Work performed by Princess Craft RV.
  • Alde heat: System inspected, flushed, and refilled with Romax. Work performed by Princess Craft RV.
  • Tires: All new tires including the spare. They are load range D and balanced. They have been on for less than 1000 miles.
Modifications:
  • Clear lavatory door is covered with a frosted film.
  • On-board EMS: Progressive Industries 30amp EMS installed inside the trailer.
  • Air conditioner: Frigidaire with a thermostat. More comfort and quieter too.
  • Charging upgrade: Original 1amp USB A charging ports replaced with 10amp USB A Quick Charge ports and USB C Smart ports. Plus an off switch.
  • Kitchen faucet upgrade: Original plastic faucet replaced with a folding brass faucet.
  • Lavatory faucet upgrade: Original replaced with a smaller faucet with a pull out sprayer plus a soap dispenser.
  • Sound system: Original plastic speakers replaced with Pioneers. The sound is much more clear and defined.
  • Upgraded Table: Original small table replaced with a larger natural pine table. Large enough for 4-person dining or playing a board game. Original small table available on request.
Contact us by leaving a message at 817-231-2337 on send an email to Tab320cs@yahoo.com.
2018 320CS-S
"Just Enough"
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,036
    @Mickerly - please edit your ad to include price.
  • MickerlyMickerly Member Posts: 472
    Sorry. I'm asking $15,800 or best offer.
    2018 320CS-S
    "Just Enough"
  • fbunnerfbunner Member Posts: 1
    My wife and I have a teardrop but are considering an upgrade.  A few questions about your camper:
    1). Are you the original owners?
    2) The work on replacing the floor- was that because of damage or just responding to recall?
    3) When was the last time bearings were inspected and/or replaced?
    4) How has the camper been stored when not in use?
    Thank you for any additional information you can provide.  Looks like you have taken really good care of it.
    We are the second owners. We purchased the '320CS in December of 2020. It is an outstanding camping trailer and we have used it at least every month since March 2021. We are preparing for retirement. Last October, we found a trailer that is better for traveling. It has both a dinette and bed plus more room to move around if the weather is bad for a few days. We aren't retired yet and don't have the time to use both trailers.
    The floor was wrinkling up. The previous owner had not exercised the recall for the floor replacement. I thought it would be nice to have a flat floor. When Princess Craft disassembled the trailer and removed the old floor, they discovered water stains at the two bottom corners of the kitchen hatch. We replaced all the plywood under the kitchen with Asdel flooring. The replacement floor is a light gray. It matches the rest of the trailer much better than the fake wood that was there before.
    The wheel bearings and brakes were replaced in February 2021. I didn't have any records from the trailer's previous life and the brakes were completely warn out. They were last repacked in December 2024. There was half the brake pad thickness left. We have used the trailer twice since for about 500 miles distance. When we were using the trailer a lot, the wheel bearing were cleaned, checked and repacked every 6 months.
    The trailer is parked along side my house. It is on cement pave stones. The tires are not touching the grass. The trailer is covered. Once a quarter, I power up the trailer to make sure everything is working. I jack up each side, spin the wheels, and set them back in a new spot. As I said, we have used it a couple times since buy the larger trailer.
    While the trailer was disassembled for the new floor, Princess Craft flushed, inspected, and refilled the Alde system with new Romax fluid. Alde recommends fluid replacement every 2 years. The next service is due in May 2026. The system was checked for corrosion 3 time while I owned the trailer (when I bought the trailer, the fluid change I did, and the one Princess Craft did). No issues were discovered.
    2018 320CS-S
    "Just Enough"
