2016 T@B 320S for sale, $16,000 low miles, lots of extras, everything works
JohnMcCJohnMcC Member Posts: 2
2016 Nucamp T@B 320S, low miles, everything works.  silver exterior with gray trim.  Cute camping trailer sleeps two and at 1,765 lbs dry weight easily towable by most SUV’s and small pickups. I”m including pretty much everything. Trailer is in Scituate, MA   price $16,000  contact me at chasemcc@verizon.net for photos and questions
upgrades, modifications and recent maintenance:
PahaQue side tent doubles your living space, fits either side.  Made specifically for this model
PahaQue large “visor” fits either side, made for this model
3 outside window awning covers offer privacy when windows are open
seating gently modified to allow for 26” twin beds (5” wider than normal).  can easily be reworked to original queen bed
full size unused mounted spare tire dates from 2018  additional mounted spare as well
extended platform in front with 2 additional stainless steel locking storage boxes; also in front is enclosed storage for waste disposal tube.
Alde heat transfer fluid replaced fall, 2024 by previous owner
undercarriage steel components (stabilizers, step, jack, spare tire mount) refinished 10/2025
tires replaced 10/2025 (very little tread wear but they dated from 2016)
bearings greased 10/2025
Smoke alarm replaced 10/2025
LP and CO alarm replaced 10/2025
surge protector for 30 amp electrical service
table support replaced with one that adjusts height and swivels, Lagun knockoff.
2   4” memory foam toppers in cotton covers for beds if wanted (unused since laundered)
wheel chocks, stabilizer pads, leveling pads
Masterlock trailer hitch lock
trailer tire leveler
potable water hose, 50 psi water line regulator, water filter (used 4 days)
exterior washed and waxed and upholstery steam cleaned 9/2025
factory features allow for boon docking or use of electric and water hookups:
30 amp shore power cable; integrated120 volt GFCI system, 12 volt system, converter; solar hookup
fridge runs on battery, propane, or shore power
2 burner propane stove
wet bath - flush toilet and hot shower
solid birch cabinet doors and birch plywood cabinetry; Amish carpentry
power roof vent
air conditioner
digital tank monitor for gray, black and fresh water tanks
Alde system for heat and hot water; can be used for heat when dry camping in cold weather
Alde digital control pad
Jensen television, radio, CD and DVD player with remote; digital antenna
fire extinguisher
seating area with table converts to queen or twin beds.
tank capacities:  11 gallons fresh water, 19 gallons gray water, 5 gallons black water; 20 lbs propane.
dry weight 1,765 lbs
T@B user’s manual and manuals for individual components
defects: exterior trim has separated in a couple of places, this is common and not structural.  There are some minor repairs to this sealed with clear silicone.  I’m pointing this out because it’s not especially noticeable.  The trim is cosmetic.  There are also a few small dents in the exterior shell.
currently winterized but will demonstrate that everything works and rewinterize for you with a deposit in hand.
