It's kind of like the keys for Yakima racks, boxes, etc. There is a finite number of key patterns. If you know the number of your lost Yakima key you can just ask any dealer for a replacement or buy it online.
San Francisco Bay Area 2013 CS-S us@gi 2015 Toyota Tacoma PreRunner Double Cab
Are you are comfortable that others may have the same key as your RV? I’m not.
Padlocks, door locks, bicycle locks etc in my opinion all have I believe exclusive keys: or at least there are 1000’s of variations. So, how many different keys might there be? Or, what is the repeat factor? Gosh, this is a rabbit hole…
Slightly off-topic, but this thread makes me wonder about my key. I replaced the new style door lock on our 2020 T@B with an aftermarket standard type like the ones found on older nuCamp's. It's probably a safe bet that the RVLock GripLite RV Door Lock has the same limited number of keys in circulation.
... but I won't lose any sleep over it.
Stockton, New Jersey 2020 nuCamp T@B 320S * Jeep Wrangler 60,865 camping miles through the end of 2025
There are now several different "keys" for the Tabs, which depends entirely on the year of the trailer. On the discussion of "are all RV locks keyed the same", for the years "roughly" from 2014 until 2021 or so, all the trailers came from the factory with a standard lock that...practically everyone in the RV industry used. They mostly used a key called "CH751".
All the doors from these years are "flat" doors. The issue of the "same key across the campground" brought up the nicer, more secure, RVLock, which had keypads and remotes as features. A lot of owners installed these locks, it was a simple process. There was a huge thread about this in 2017 that shows the locks, installs, etc.
After 2020, the NuCamp started installing a molded plastic door. The door lock is significantly different, more secure, and comes with "unique" keys. The locks themselves are considerably different compared to the "flat" doors. None of the "RVLock" type locks will fit this door.
Shouldn't you have the same concern about your house key and your car keys? Keys are not unique. Some lock manufacturer like Medeco and Assa Abloy restrict certain keyways to certain regions in an attempt to make it harder to duplicate a key. I had a renter try to get a duplicate of the apartment key and the locksmith called me, so in that case it worked?
Adventure Cats living in the Pacific NW USA 2022 NuCamp T@B 320S Boondock 2023 Volkswagen ID.4 Pro S Plus AWD
St Catharines, ON
2013 CS-S us@gi
St Catharines, ON
Moderator
2019 T@B400 Boondock Lite "Todd"
