Dewinterizing 620
johnVT
johnVT Member Posts: 44
hi folks,
I’m de winterizing my Cirrus 620 for the first time. I’m following the video that NuCamp posted. how much sanitizer solution should I expect to be sucked up? Am I filling the tank? The video says wait till the water system is pressurized but I’m to my fourth 5 gallon pail of solution. Is that normal?
  • db_cooper
    db_cooper Member Posts: 749
    I would think that's normal,  since it holds 20 gallons plus water lines.
    We use the blow out method, so not concerned about flushing any RV antifreeze out of the lines. I sanitize with spa chlorine granules.  I put a teaspoon in the hose and hook it up, fill the tank normally.  Drive around a bit,  let it sit a few hours and drain and then fill again.
  • johnVT
    Thanks DB. I got it sorted things out eventually. Dewinterizing in VT when it’s only 12 degrees the morning I needed to do it was a bit of a challenge. It warmed up to 45 eventually. LOL. Good time of year to head south for a spell!
  • Horigan
    Horigan Member Posts: 920
    I personally don't fill the tank since only the very bottom of the tank has water on it during the winter.  I put in just enough sanitizing fluid to fill the lines and just a bit in the tank.  This for me makes it easier to flush the system of all the sanitizing fluid.  Do this on my boat as well.
    Rich
    2019 T@b 400
    Bellingham WA
  • johnVT
    Thanks Rich. I’ll keep that in mind for next season’s dewinterization.
