Dewinterizing 620
johnVT
Member Posts: 40
hi folks,
I’m de winterizing my Cirrus 620 for the first time. I’m following the video that NuCamp posted. how much sanitizer solution should I expect to be sucked up? Am I filling the tank? The video says wait till the water system is pressurized but I’m to my fourth 5 gallon pail of solution. Is that normal?
I would think that's normal, since it holds 20 gallons plus water lines.
We use the blow out method, so not concerned about flushing any RV antifreeze out of the lines. I sanitize with spa chlorine granules. I put a teaspoon in the hose and hook it up, fill the tank normally. Drive around a bit, let it sit a few hours and drain and then fill again.2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Thanks DB. I got it sorted things out eventually. Dewinterizing in VT when it’s only 12 degrees the morning I needed to do it was a bit of a challenge. It warmed up to 45 eventually. LOL. Good time of year to head south for a spell!0
I personally don't fill the tank since only the very bottom of the tank has water on it during the winter. I put in just enough sanitizing fluid to fill the lines and just a bit in the tank. This for me makes it easier to flush the system of all the sanitizing fluid. Do this on my boat as well.Rich2019 T@b 400
Thanks Rich. I’ll keep that in mind for next season’s dewinterization.0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
