How to winterize a 2013 tab 320s with Bradford white electric water heater.
rodriguezr
rodriguezr Member Posts: 5
we just purchased this trailer this summer as a gift to ourselves. But most of information is for newer models with the alde heater. Any help would be grateful.
Answers
    pthomas745 Administrator, Moderator Posts: 4,703
    Welcome to the Forums! We would love to see some photos of your water heater setup. There are several threads about the Bradford.
    It appears it is the 2 gallon Bradford. This link goes to a thread that shows the model number as M1-2U6SS. (See the comment from "Ron and Amy" towards the bottom.)
    Bradford Water Heater Info
    It appears one of those links are broken, but the link to the product description does have the product brochure.
    This is another thread with some more info from owners who have the same Bradford setup.
    Another Bradford Setup Thread
    Along with the Bradford tanks, some trailers had the Rheem small water heaters. This thread, towards the bottom shows pictures and has a discussion.
    Rheem water tank description
    So, send us a picture of your tank, and lets see if the hive mind can give you a decent start.
  • rodriguezr
    Thank you. I will check out the links. I cannot locate a hot water drain valve other than the pressure relief valve.
  • rfuss928
    rfuss928 Member Posts: 1,196
    edited November 5
    These small tanks do not have drain valves.
    I separate a fitting on the hot water exit and supply ~40 psi air pressure to the tank while opening a cold water faucet. The pressure pushes the water in the tank out the cold water supply line which has a dip tube in the tank. This drains the tank down to the bottom of the supply dip tube. Not empty but seems to be enough as I have had no issues after three winters in western NY.
    This is the worst step of my winterizing chores
    Good luck - have fun…
  • rodriguezr
    thank you. I will give it a try!
  • rfuss928
    If it is more accessible, you can pressurize the tank through the pressure relief valve by manually opening it with the lever on its top. Your photos show a union in the discharge pipe (I think) that looks to be easily accessed to connect an air pressure source.
  • rodriguezr
    @rfuss928, can you share a pic of where you connect on the hot water side and the he compressor adapter you use? I am guessing I could use either hot water sink line. Disconnect from the sink and configure an adapter to blow air backwards as you indicated. Is that correct?
  • rfuss928
    edited November 6
    My system is quite a bit different than yours but has the same fundamental problem of inability to drain the electric water heater to winterize.
    The red line in the upper right is the hot water out of my Bosch electric water heater (just visible along right edge). The vertical black check valve is ~~easily disconnected and an air gun with a rubber cone tip is held in the open fitting.
    If your system has a check valve similar to mine you will not be able to back flow past it. But yes, basically you want to blow backwards into the tank outlet and let water exit the cold water inlet somewhere.
  • rodriguezr
    thank you! This is very helpful
