Supplementing Solar Capacity
Last year , I purchased a lightly used 2022 Tab 320S Boondock which came with a single roof mounted solar panel (approximately 100W I believe), a Victron 75/10 Controller, and 2 Battleborn 100 Amp Hr Li batteries (all factory installed).
I am interested in using portable solar panels (200-300 Watt) to supplement the rooftop panel while boondocking. However, there is no port for supplemental panel connection in my front, tongue mounted diamond plate battery/propane storage box. Also, I believe the existing controller is inadequate for additional panels.
I am hoping foor some input from others on the following:
- Should I upgrade my existing controller to handle the additional panels or add a second controller? If the latter, would the two controllers interfere with one another?
- How difficult is it to run wires from the tongue mounted storage box to the current controller location (under the driver side seat)? I was thinking adding a port to the box to plug in the portable panels when needed.
Any other insights/recommendations would be greatly appreciated.
mwjoe
You don't need to replace or upgrade your 75/10 controller. Add a second one inside the tongue box close to the battery and network it with your 75/10 in the Victron app. They will talk to each other for more efficient charging. I'd suggest going with at least a 100/30 for potential future solar suitcase upgrades. You'll need to add a port to the side of your tongue box, but it's an easy task. I started with the same SAE type port that nuCamp uses, but have switched to Anderson.
60,865 camping miles through the end of 20253 -
You need a separate controller if you use supplemental panels. There is really no good way to "string together" the current panel on the roof to a separate panel. The 75-10 Victron is a good match for the 100 watt panel on the roof. Your idea of an extra panel set up is a good plan, but the two solar setups will be completely separate.
There are a lot of ways to wire up the separate controller to the battery. You can attach a "dongle" directly to the battery that you can make available to your controller wiring. You would just leave the "dongle" attached to the battery and outside the battery box for access. If you have the skills, you can wire any of the number of "solar connectors" to the side of the tub and wire the connector to the battery. You can mount the separate controller inside the tub in various ways, wire it to the battery, and use the "dongle" or an installed solar connector on the tub to connect the panel to the controller.
There are lots of ways to do this…even simple battery clamps directly to the battery from the controller outside the tub.
My portable 200w solar suitcase came with an attached controller. I removed the controller from the suitcase and mounted it inside the 320's front tub behind the port I installed. Having the controller closer to the battery lowers the voltage drop when using a long cable when setting the panel out in the sun.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York2 -
If you use the Victron Energy app to monitor your existing controller, then a second Victron Energy is a good idea because they will network together and communicate with each other. We have a 2022 400 with the roof mounted solar panel. I added a second Victron Energy controller with an exterior sae connection. I can monitor both controllers and the Victron Energy Smart Shunt with the app. Like SLJ, I have a Renogy 200w suitcase panel with a controller like his. Since I added the second Victron Energy controller, I removed Renogy controller from the solar panel, but carry it with us on trips in case I need to use the suitcase panels to charge our tow vehicle or help fellow travelers charge something.
2022 T@B 400 BD, 2018 Toyota Tundra, Palisade, CO0 -
Thanks to everyone! I plan to go with a second Victron controller. Still trying to figure out which panels to use.
I’m a real fan of the new Renogy 100W N-type panels. I’ve been using them and they’re sturdy but lightweight and very easy to set up and affordable. Renogy has a good track record - they’ve been around for a while.
I have 2 panels and I bring one or both, depending on where I’m camping. It looks like Renogy will soon be offering a 300W panel but I would still prefer 2 smaller ones.
2021 320S BD
2017 F-150
Coeur d'Alene, Idaho1 -
Interesting @WayneW. We have one of the older Renogy 400W suitcase. It works well, but it's a bit bulky. Wondering if this new 300W panel would have the same or more output and be easier to pack and deploy?
60,865 camping miles through the end of 20250
