Battery storage compartment
Sebenius
Member Posts: 5
We are the new owners of a 2016 Q-max. This might sound silly but...while hunting for our T@B, I noticed inside practically every battery/propane storage box, there is a piece of 4" PVC pipe attached vertically to the front....what is this for?
Many of us store our dump hose in there and the dump end fits in that pvc pipe.
Mine curls up on top of the battery box with the end held in place in that pvc. -
Congrats! A lot of dealers include a cheap sewer hose and they fit in the PVC. I am pretty sure most of the better hoses don't.Sebenius said:We are the new owners of a 2016 Q-max. This might sound silly but...while hunting for our T@B, I noticed inside practically every battery/propane storage box, there is a piece of 4" PVC pipe attached vertically to the front....what is this for?
Jenn - My Rhino fits great.
Thanks. Now I will sleep at night...;)
I keep the elbow on all the time, so it didn't work for me.PXLated said:Jenn - My Rhino fits great.
I have this elbow on mine and it fits just fine - You have something different?
That's what I have, but it didn't fit. Maybe our PVC was a different size? Do you use the cap?PXLated said:I have this elbow on mine and it fits just fine - You have something different?
Cap - No, I figured fresh air up thru the hose was better than sealing it off.
Before I swapped out the plastic front bin with the diamond plate one, I had that PVC pipe for the sewer hose. It was perfectly round for about 5 minutes and held a 10' hose with the elbow ball-bungied inside the bin for security. Then the pipe decided being round was too conventional and it made putting the sewer hose in it near impossible. It was a good idea, but my little piece of PVC pipe was a rebel (alas!). I was going to replace it with a larger PVC pipe, but decided I needed some more room in my front bin.
Since swapping out the bin for diamond plate (non LG one), I have 3 more inches all the way around (including height) and have 25' of hose happily snuggled in the bin and there is plenty of circulating air to keep it dry.
If your PVC pipe rebels, I would suggest replacing it with a larger diameter pipe or do a search to find all the cool mods people have done to store those hoses!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart) -
To be clear, I don't feed the hose into the pipe, I just seat the dump end connector in and then curl the collapsed hose on top of the the battery box.
Mine cane with a cheap hose in it.PXLated said:To be clear, I don't feed the hose into the pipe, I just seat the dump end connector in and then curl the collapsed hose on top of the the battery box.
- 915 Tips & Tricks
