Mopar brake controller
JK5756
Member Posts: 25
I just installed the Mopar brake controller in my wife's 2012 Grand Cherokee. Pretty simple plug and play. However, the red led light remains on when the vehicle ignition is off...is this normal?? Does the brake controller stay hot all the time? Sorry if this is a silly question but I'm a newbie and don't want to wake up to a dead battery. Thx
The Prodigy stays lit 10 or 15 minutes and then goes out. If yours doesn't go out after a time I'd definitely find out if its right but it might be OK. My security system blinks continuously and I sometimes go two weeks between starts on the vehicle.2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
Guess I was a little impatient...went back and checked and the light is now out. Thx db!
Where did you mount it? I have a temporary mount to the left of the steering wheel but there think I am going to move it to the little media cubby in the center.JK5756 said:I just installed the Mopar brake controller in my wife's 2012 Grand Cherokee. Pretty simple plug and play. However, the red led light remains on when the vehicle ignition is off...is this normal?? Does the brake controller stay hot all the time? Sorry if this is a silly question but I'm a newbie and don't want to wake up to a dead battery. Thx
I mounted it under the steering column area just to the right side. Not real sure I like this location, may be moving it.
That's just about where my temporary mount is.JK5756 said:I mounted it under the steering column area just to the right side. Not real sure I like this location, may be moving it.
- 915 Tips & Tricks
