Water Pumping problem
DaveLu_Explorers
Member Posts: 15
Any ideas? We are on our first boondocking trip after owning our T@b for a year. It's a 2015 S-Maxx Sofitel
We don't seem to get enough water pressure in both the shower and sink. Water is intermittent or sputtering instead of flowing.
Pump switch is ON.
Could there be a problem with the water pump already? Should we take in for a checkup?
Dave and Lucia - Atlanta GA - Acura MDX - 2015 T@B Sofitel S
Check the filter on the " in " side of the pump
- Hash T@B Fun
Also check the faucet filter for pipe shavingsVerna, Columbus, IN
Are the lines bled for air? That can drive you crazy for 2+ gallons...
J.D. & Sue
How do you check and bleed air out of the water lines?DurangoTaB said:Are the lines bled for air? That can drive you crazy for 2+ gallons...John and Henrietta, Late 2016 T@B S Max in Western New York0 -
Check out some of the tips in this recent thread. Good luck.
http://www.tab-rv.com/forum#/discussion/2547/water-pump-issue-solved-2016-t-b-q-max-outback-edition
Unfortunately I don't understand any of that!John and Henrietta, Late 2016 T@B S Max in Western New York0
