Water Pumping problem
Any ideas? We are on our first boondocking trip after owning our T@b for a year. It's a 2015 S-Maxx Sofitel
We don't seem to get enough water pressure in both the shower and sink. Water is intermittent or sputtering instead of flowing.
Pump switch is ON.
Could there be a problem with the water pump already? Should we take in for a checkup?
Dave and Lucia - Atlanta GA -  Acura MDX - 2015 T@B Sofitel S
  • Dalehelman
    Check the filter on the " in " side of the pump
    1. Hash  T@B Fun
  • Verna
    Verna Member Posts: 6,876
    Also check the faucet filter for pipe shavings
  • DurangoTaB
    DurangoTaB Member Posts: 754
    Are the lines bled for air?  That can drive you crazy for 2+ gallons...
    J.D. & Sue
  • Photomom
    Photomom Member Posts: 2,217
    How do you check and bleed air out of the water lines?
  • Photomom
    Unfortunately I don't understand any of that!
