Stereo Display too bright at night
chickarosa
Member Posts: 11
Hi again, we slept in our new T@B Q to test the mattress for sleeping. We are getting a foam topper. I absolutely adore our T@B, but would like to know if any of you are bothered by the stereo display light at night while you are trying to fall asleep.
I eventually went and got a dark bath towel and pulled the TV out and put the towel over it to partially hide it.
can the display brightness be turned down?
Thanks for any help.
Chickarosa
Chickarosa
Do a search on "Jensen" - There's been at least a couple discussion on this - As I recall, there's a way to dim it or even shut it off - Might be in the manual also.0
it is in the manual ... though I haven't done it yet ... will need to do for the next trip ... note the Alde panel (on a 2016) is also quite bright.John & Lisa, 2016 M@x S, Silver/Yellow, Hood Canal, WA, TV = 2008 Toyota FJ Cruiser0
The T@B manual?0
There is a + or - dimmer display button in the upper left hand corner of the stereo.2015 T@B 320 S, 2019 Jeep Cherokee
Thanks I will check that out!0
I do know the Alde digital display can be put on a "blank screen" stand-by. It is bright (for me). It's under the "wrench" looking icon indicating setup/tools on the display.
There are different Jensens in different model T@Bs. Mine doesn't have bluetooth (ok with me). I can dim the display, but it will default to bright again if you use a cut-off battery switch while storing the unit. Clock has to be reset too (not a big deal for me either - I'm lucky if I can remember what year it is).2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
Mine is a night light for those 2 am nature calls. Dim blue light is a lot easier on sleepy eyes than the white bathroom LED.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”3 -
I have zero light curtains in my bedroom at home. I've learned how to feel my way around. So far I've managed not to pee in the waste basket.Verna said:Mine is a night light for those 2 am nature calls. Dim blue light is a lot easier on sleepy eyes than the white bathroom LED.
3 -
An early mod I did was to install a cut off switch just for the stereo system so I could turn the light off completely. I posted about it in the Little Guy forum before there was a dedicated T@B forum.
Sterling, VA0 -
LOL we never k ew you could dim the bas... Er, light. Cardboard taped over the display- and a baseball hat hangs on my Progressive monitor. We even taped over the TV led, which is like a beacon inside the reflective li'l Tab.
LOCATION: Fort Raccoon; UNIT: 2014 T@b S M@xxxx; MISSION: To have fun, make a difference, and make some friends along the way. Organ Donor Recipient- forever grateful.0 -
I wasn't able to dim the display to a sufficiently low level of brightness so I attached a small piece of window tinting material with velcro. At night I just flip down the flap to block the light.2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota2 -
Thank you all!0
Andrew P.
Durango, CO
2015 S Outback1 -
Love the idea of those dimming sheets! After three trips in our t@b, I now carry post-it notes to cover the stereo and black electrical tape for the tv power light. I can still see the smoke and CO detector lights, but am toughing it out with them for now.AZ - 2016 T@B-S Outback Silver/silver0
