Hi again, we slept in our new T@B Q to test the mattress for sleeping. We are getting a foam topper. I absolutely adore our T@B, but would like to know if any of you are bothered by the stereo display light at night while you are trying to fall asleep.
I eventually went and got a dark bath towel and pulled the TV out and put the towel over it to partially hide it.
can the display brightness be turned down?
Thanks for any help.
Chickarosa
0 ·
There are different Jensens in different model T@Bs. Mine doesn't have bluetooth (ok with me). I can dim the display, but it will default to bright again if you use a cut-off battery switch while storing the unit. Clock has to be reset too (not a big deal for me either - I'm lucky if I can remember what year it is).
Happy Trails Y'all
Happy Trails Y'all
Sterling, VA
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
http://www.amazon.com/Dim-®-light-dimming-sheets/dp/B006R0VWSG
Durango, CO
