With the switches in the off position it appears my interior and porch light has residual current going in it and still puts out a dim light while on shore power is this normal are has anyone else notice this
With this limited information I would suspect that the shore power ground is faulty. A common error is the hot and ground side of the shore outlet is swapped or a similar error in the extension cord creating a condition often called "hot skin" in RVs. You could use a receptacle checker in a T@B outlet to investigate. If the outlets check faulty, the error may be in the shore power connection. This is quite a leap from the info provided - but possible. Also be aware that the phosphors in some LED elements have some persistence and will glow for a while after being powered. Have fun! Bob SUNT@B
Careful, too, if the problem is that the CG wiring is bad, causing campers with 'hot skin', as rfuss mentioned. This situation can cause dangerous shocks if you happen to be a conductor between a camper's electrified 'skin' and the earth. For example, touching a metal-bodied camper while standing barefoot on the ground.
Testing the outlet is a good idea at every campground.
Also, you'd be smart using a surge suppressor that has a built-in 'hot-ground' protector, like the Progressive brand ones do, to guard against it.
Chan - near Buffalo NY 2014 S Maxx 2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah! A_Little_T@b'll_Do_Ya
I installed a Prod Ind EMS-HW30C early on and it has detected bad power several times since. Campgrounds sometimes have marginal wiring that struggles when pushed to capacity. But that is another topic!
