A/C problem
Verna
Member Posts: 6,876
This discussion was created from comments split from: Out with the CoolCat, In with the Frigidaire 6K Btu Window A/C.
Im on my maiden voyage. Temp hit 105 in late afternoon. AC It quit cooling and came back on after "cooling off". I'm in an RV park on a golf tournament. No tree or other shade, T@B s max. About 15% humidity. Any one else have this happen? Can I get a larger unit for the T@B? Everything else working fine. Did nearly get a burn from water coming through hose into coach during this time. That will get your attention while trying to get a quick shower.Ramblin' scramblein' Tumb@lweed Gray/Red 2016 Max S, Wichita Falls Texas
What ever you do, what ever your goal, keep your eye upon the donut and not upon the hole.0 -
When the AC quits cooling, it means it's overheating. The baffles set up in the factory are very important to divert the hot air out and fresh air in. The additional circulating fan is important and if I remember your picture, you might need a bigger fan because the window unit is smaller than the Coolcat was. Just a few thoughts.
I only say the AC shuts down when overheated because I forgot to take my AC "cover" off and the AC stopped cooling. When I went outside for something else, I had a D'oh moment.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
@Annieoakley, I believe you have a newer T@B model. Make sure you turn on the auxiliary fan (switch next to the A/C cabinet). This helps the hot air to be released from cabinet. My A/C has been running constantly since last Sunday, minus daytime Monday, and has kept the inside temp at 70*.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”1
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
