Black water tank assembly fell off!
Cheryl74074
Member Posts: 71
Sometime yesterday while driving home from Tearstock, our drain/valve assembly from the black water tank fell off.
Luckily, we had visited the dump station before leaving Atwood Lake...
Has anyone ever heard of this happening??
Cheryl
2015 T@bitha (SMaxx)
Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)
Yuk and yikes! Where did it break off?
J.D. & Sue
It looks like it was supported by a metal strap that came undone on one side. There's nothing left of the pipe assembly, just a round hole on the bottom of the T@b where it attached to the tank. It could have been really gross, but the tank had just been emptied.Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)6
Definitely could have been a real mess. Contact your dealer as this should still be covered under warranty, they should be able to help you.
Sterling, VA0 -
Unfortunately we weren't really impressed with the dealers knowledge of our model of the T@b. Plus, they are over 2 hours away. I'm hoping that Little Guy can send us the parts and we can have it installed locally.Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)2
"Sh&% happens."
This should be an easy fix. The parts aren't proprietary from what I can see... ...and in a pinch are available at a larger RV parts supply store or online (in case you need it prior to a part getting sent). LOCATION: Fort Raccoon; UNIT: 2014 T@b S M@xxxx; MISSION: To have fun, make a difference, and make some friends along the way. Organ Donor Recipient- forever grateful.0 -
*I couldn't resist... this is the same line uttered when my friend had a collision on route to a dumping station. Someone hit him... and need I say what the results were? Yuck doesn't cover it (large 5th wheel RV)LOCATION: Fort Raccoon; UNIT: 2014 T@b S M@xxxx; MISSION: To have fun, make a difference, and make some friends along the way. Organ Donor Recipient- forever grateful.0
Finally had a chance to talk to Ed Kaufman today, and it turns out we're not the only ones with this problem!Apparently the glue that they've been using recently hasn't been holding, so they are searching for a glue that will hold plastic to ABS. If you have a new trailer, keep an eye on your drain pipes!Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)1
So where else have they used this alleged glue? I wonder if it is somewhere where we can't easily self-repair.0
I'll be keeping an eye on the grey water drain pipe, but I don't know where else it's been used.I'll be talking to Ed again tomorrow, so I'll ask about what else we should be looking for...Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)1
They've found a glue that will work to repair this. I was told that the problem was only with the drain pipe from the black water tank, because that tank is made from a different plastic than the drain pipe plastic.The grey water tank is the same plastic as the pipe, so that shouldn't be a problem.If you have a recently built T@b, keep an eye on the black water drain/tank assembly!!!Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)0
Hey Cheryl, what are the last numbers of your VIN? We are #22. Did you actually get some of the new glue to repair it?
Paula & Larry | 2015 T@B S M@XX "Serenity"| 2014 Subaru Outback | Maple Grove, MN0 -
I think the last 3 numbers of our VIN are 147.We are planning a road trip from Oklahoma to New England, so we're going to stop in Sugarcreek- so they can fix it.I think they will send you some glue if you have the same problem, or at least tell you what kind of glue you need to use!Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)1
Fingers crossed that we won't have the problem. Thanks for sharing. At least if it happens we won't be too surprised and will know that there is a resolution. And all the more reason to stay with a "no #2" rule.
Paula & Larry | 2015 T@B S M@XX "Serenity"| 2014 Subaru Outback | Maple Grove, MN1 -
Paula & Larry - I am #27.
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
