Does anyone use a Goal Zero generator to suppliment power on their T@B? If so, how do you use it? I'm considering a Yeti 400 which has a chaining port so our Zamp 80 watt panels can be used to charge it. Wondering it the Yeti can simply plug into the T@B shore power plug-in.
0 ·
888-794-6250 (Goal Zero).
Seattle, WA
Considering losses in efficiency, you might be able to put in 10-12 AH from a fully charged Yeti, into your campers battery.
Best to save the battery for your lights and fridge, then use Yeti for CPAP.
2014 T@B CS Maxx
Martha Lake, WA
Guess I knew the Goal Zero could not fully charge a group 24 battery but was hoping it would be enough to keep the Alde pump and controls work for a day or two on a cloudy day.
Thanks for doing the math.
British Columbia, Canada
In the T@B 400's that are equipped with the optional inverter, only a single 110V outlet is powered and only when the inverter is switched on. Both the outlet and the on/off switch is located on a panel at the foot of the bed on the right side of the kitchen cabinet.
