Replacing stabilizing jacks with leveling jacks (Revisited)
edited December 2018 in Modifications & Upgrades
How to install rear leveling jacks. With no modification to jacks or trailer. A simple adapter plate can be made from an 11" piece of 2"x 3/16 flat piece of steel from Home Depot.
The yellow circle measurement should be
5 1/4” not 5 3/4”
Tools  required  are a hack saw and drill with 7/16" drill bit. 3/8"x 1"  carriage bolt. For the best fit the dome on the bolt can be filed or ground down flat.
  1. Hash  T@B Fun
  • rfuss928rfuss928 Member Posts: 980
    edited December 2016
    Nice description!!
    BTW - Lowes (and other hardware stores) have "elevator bolts" which are a flat head version of "carriage bolts".  Might save a little filing.  Just FYI
  • DalehelmanDalehelman Member Posts: 2,410
    rfuss928 said:
    Nice description!!
    Correct thanks for the input.  Most people would not know what an elevator bolt is.  Could not find them at Home Depot. Lowe's does carry a much larger selection.
    1. Hash  T@B Fun
  • dsatworkdsatwork Member Posts: 744
    I get drilling holes but, how do you get the square cut out for the "carriage bolt" or "elevator bolts"?
    Use a square file or hammer to drive it home. Tightening it down with nut will also work. The adapter should be bolted to the jack first then bolted to trailer.
    1. Hash  T@B Fun
    Nice description on the install Dale! Now, back to the lawn chair & another cup of coffee for the next mod! ;)
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
    You bet. This is an inside joke between ericnliz and I but true.
    1. Hash  T@B Fun
  • HomebodyatheartHomebodyatheart Member Posts: 2,509
    If I'm sitting by Eric i will be taking notes... :-)
    I DO get mine in once in a while! =)
    Eric aka: Lone Wolf
    Dale, we may want to split this off to another discussion. But with all the mode you've done, I see you still have the tire mounted under the trailer. Have you considered a creating a skid plate for it? I'm going to need to leave mine in place and all the discussions seem to center around moving it because it drags potentially causing damage. Dave
    In nearly 3 years and over 8000 miles I have never had any problem with the tire mounted underneath. I am mindful that it is there though. With storage at a premium I am pleased the builders mounted it there they did.
    1. Hash  T@B Fun
    Dale thanks that's good to know
  • TabberJohnTabberJohn Member Posts: 588
    Suggest you edit this post (like the original) to include a pic with jack closed so people can see how small that is.
    Good idea
    1. Hash  T@B Fun
