Project scope creep - Repacking bearings
db_cooper
Member Posts: 749
What started as just adding grease through the grease zerk, turned into a full repacking session. Both wheels on our 2 year old Outback had some play, drivers side a bit worse than the passenger side. I'm guessing there's no more than 3000 miles on the trailer. The drivers side needed to move about 3 notches to take out the play, while the other side only one. After determining how much play there was, I decided to inspect all the bearings and races. They looked fine, so I repacked with grease and put it all back together. No play now, so glad I checked, as I really thought doing the bearings every year was overkill. Not a tough job, and now I know what's going on in there.
I'm wondering if they were over cautious at the factory about over tightening, or is it normal after a little wear in?
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
- 915 Tips & Tricks
