Removing cushions
Seaduster
Member Posts: 147
Has anyone removed the sticky command strips and staple from the wall behind the cushions? If so, did it ruin the wall's surface? I'd like to permanently remove the corner cushions.
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
You will still see the holes from staples.
- Hash T@B Fun
Did it peel off the wall covering under the velcro strip? Thank you!Deb - 2017 T@B U-basic Outback silver/silver D@mselfly
2001 Toyota Tacoma 4WD New Mexico0 -
OK to remove Velcro from walls. I did so and can't see staple holes unless I really look for them. Just take it slow and pull staples straight out.2016 Outback 320
Agree with OutbackAZ. We removed ours and you have to look real close to see the tiny staple holes. Peel slowly, then use magic eraser for any residue.Geo & Liz
T@BMahal
'04 #1000 -
Use a hairdryer to heat up the velcro tape so it will peel off easier.Dont get it too hot or you will damage the wallpaper.2014 T@B M@XS; 2017 Ford Transit Low Roof, Reg. Wheel Base1
I 2nd the hairdryer. It's also good to take off any vinyl stickers outside you don't like. The residual glue can be taken off with a variety of solvents. Start with the weakest and move up. My walls were painted and had no wall paper, so I can't tell you which stuff to use to get rid of any residual glue without damaging the wall paper.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
- 120 Dutchman and Vintage TaB Archives
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
