Removing cushions
Has anyone removed the sticky command strips and staple from the wall behind the cushions?  If so, did it ruin the wall's surface?  I'd  like to permanently remove the corner cushions.
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
  • Dalehelman
    You will still see the holes from staples.
    1. Hash  T@B Fun
  • reedd
    reedd Member Posts: 61
    Did it peel off the wall covering under the velcro strip?  Thank you!
    Deb - 2017 T@B U-basic Outback silver/silver  D@mselfly
    2001 Toyota Tacoma 4WD New Mexico
  • Tabaz
    Tabaz Member Posts: 2,420
    OK to remove Velcro from walls. I did so and can't see staple holes unless I really look for them. Just take it slow and pull staples straight out.
  • Geo
    Geo Member Posts: 160
    Agree with OutbackAZ.  We removed ours and you have to look real close to see the tiny staple holes.  Peel slowly, then use magic eraser for any residue.
    Geo & Liz
    T@BMahal
    '04  #100
  • KBaggins1
    KBaggins1 Member Posts: 135
    Use a hairdryer to heat up the velcro tape so it will peel off easier.Dont get it too hot or you will damage the wallpaper.
  • Ratkity
    Ratkity Member Posts: 3,770
    I 2nd the hairdryer. It's also good to take off any vinyl stickers outside you don't like. The residual glue can be taken off with a variety of solvents. Start with the weakest and move up. My walls were painted and had no wall paper, so I can't tell you which stuff to use to get rid of any residual glue without damaging the wall paper.
