Anyone else had this happen?
ericnliz
Member Posts: 4,437
Yesterday after replacing my upper door hinges above the sink/stove area ( yep, no more smashed knuckles, or head skids, they stay open now! ), I turned around, and noticed the trim around the porthole window on the inside was loose. Seems it is attached by rivets going in through the trim to the door skin, and two of them have pulled loose from the skin itself. Any one else? Taking it in next week for another warranty issue, and will have it checked out/repaired at the same time. Will report back with results.
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf
Eric aka: Lone Wolf
That's a new one on me, Eric. Tell us what you find, please.Verna, Columbus, IN
Will do @Verna. Been in & out of the door several times in the last few days, and just noticed it. Must have just happened yesterday.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
I have have a rivet gun. You might have to carefully drill out the current rivets and put bigger ones in. Best call nuCamp to verify that's a viable fix!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
Dealer first because Eric is under warranty.Verna, Columbus, IN
Ditto what V said!!! Dealer first. THEN Ohio, then DIY.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
@Verna , and our most helpful @Ratkity , After a little further investigation of the trim on the window, I noticed there was already more than one empty rivet hole under the trim ( in the two visible spots) where it may have come loose before, or during installation.....hmmm...me thinks the trim should probably come all the way off & re-positioned to a spot for some fresh rivet holes! I'll let 'ya know what the warranty guy at the dealer has to say. I'm hoping for a permanent fix, that's for sure.2016 T@B MAX S-aka: WolfT@B
When all else fails... GORILLA GLUE! Or Epoxy or something that can hold an airliner to a construction hat you're wearing.. you know... when in doubt duct tape or glue.
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1 -
@Ratkity, took me two days to get a piece of trim off my finger with my last go- round of Gorilla Glue. I'm stickin' ( pun intended ) to leavin' this one to the professionals!2016 T@B MAX S-aka: WolfT@B
ericnliz said:Yesterday after replacing my upper door hinges above the sink/stove area ( yep, no more smashed knuckles, or head skids, they stay open now! ), I turned around, and noticed the trim around the porthole window on the inside was loose. Seems it is attached by rivets going in through the trim to the door skin, and two of them have pulled loose from the skin itself. Any one else? Taking it in next week for another warranty issue, and will have it checked out/repaired at the same time. Will report back with results.
While you are out at RnR allow an extra hour and stop by. I will do the dump valve mod for you. I have all the parts on hand. Just give me a day and time.- Hash T@B Fun
Yes, happened to me. Mine is held on with plastic pieces that push through the door panel and hold it in place. I had some nylon screws and was able to fix it that way, as the panel is thick enough that I could get a couple of threads in it. Christmas tree bolts would be a better option, but the ones I had were large and dark colored. I expect they can be found in white to match the door panel and trim ring.Marc and Angie in Burlington, NC. 2018 Ford F150 FX4 3.5L Ecoboost, 2016 320 S Max0
Christmas tree bolts?
- Hash T@B Fun
They are used primarilly in automotive to hold trim together. Lots of different types, but many can be found a Lowes/Home Depot. One example below:
https://www.belmetric.com/common-christmas-tree-retainers-c-12_178/a141-plastic-retainer-p-785.html?zenid=gbi8k049grhqu7freu7jap06s6
Marc and Angie in Burlington, NC. 2018 Ford F150 FX4 3.5L Ecoboost, 2016 320 S Max0 -
Subism said:They are used primarilly in automotive to hold trim together. Lots of different types, but many can be found a Lowes/Home Depot. One example below:
Learn something everyday. Now I understand the reference to Christmas tree- Hash T@B Fun
OK. I learned something today. Can I go home?
I never knew what those things were called.
Mark - 2016 T@b Max S (Silver/Red), 2012 F-1501 -
Ok, The window trim issue was too short of rivets being used to totally penetrate both the trim inside, and the trailer door skin. All four were replaced by the dealer, and I now have a happy porthole window again!
Eric aka: Lone Wolf2 -
Eric, was that window on the door or in the bathroom?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The door entering the trailer porthole window. Unless you prefer to crawl through the bathroom window, that's the main entrance!
( that I gotta see!)
ericnliz said:The door entering the trailer porthole window. Unless you prefer to crawl through the bathroom window, that's the main entrance!
If I'm not mistaken we did have a trailer owner who was locked inside his trailer, couldn't get out and had to use his cellphone to message the forum for tips as to how he could get out without destroying his trailer. That'd be my luck!
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
@Michigan_Mike, worse would be your iPhone in the picnic table outside playing music on the Bluetooth speaker, with you stuck inside
That wouldn't be a pretty sight, me "trying" to climb out the side window!
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
@Michigan_Mike,
Would be free entertainment though!
Which brings up a point I shared with @Homebodyatheart, and @Dalehelman when we were sharing mods ( Dale won hands down BTW ). Check the screws on both the door, and trailer side of the door latch, I tightened mine the other day about 1/2 to 3/4 of a turn each. If they work their way out, it causes the door to not be able to open.
Good point and I've done that. It was amazing how loose the screws were and how much I was able to tighten them up. I've got them tightened down well now and it's a good idea to check them from time to time.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
Hey @ericnliz! I thought my table top mod was pretty darn nice! @Dalehelman just has a bazillion more mods than the rest of us put together. And he's really good at them!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
@Homebodyatheart, I'm really not trying to take away from your cool tabletop at all. I loved it. Besides, I think @Dalehelman has had just a LITTLE more time to accomplish all his mods than ALL of us put together. The good part is that it gives the rest of us pretty darn good "food for thought" don't 'ya think?
@ericnliz agreed! He has a two year jump on me, one on you, and he's so good at it all! I love how each of us has gifts and talents we bring to the group, to this forum, too.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@Homebodyatheart, The sharing part makes it all the better!!!!!
Eric aka: Lone Wolf3 -
Did have this happen to me. Grabbed the port hole to pull the door shut and broke a couple of the rivets loose. Had the trailer at the factory for another warranty repair and they fixed it for me no charge.1
@greggill, it's SuperT@BM@N! About to pop rivets in a T@B door with one pull... who knows what he'll pull off next? (could be more camping.. stories for the campfire... you know, what is said around the campfire, stays around the campfire!)2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
Just wanted to throw out a caution flag - all this talk about loose screws had me tightening all the screws that hold my trim on. Today was a particularly warm day. I was hearing a lot crackling and popping. After living so many years in the desert, I should have known better. That plastic needs flexibility (heat and cold) and if tightened too tight, it will eventually crack. So out I went to loosen all those screws back up and noticed that hot plastic giving way from the side of the trailer as if to sigh a sigh of relief! The hard plastic pieces (fresh water fill port, cable cover, etc.) can be tightened snugly, but the plastic trim is relatively thin and needs room to flex.
I am assuming the factory must know this, because all the screws that were supposed to be snug were, in fact, tightened down snug. The screws holding the trim on all had some "play."
One other thing to mention; I saw somewhere in one of these posts that some people were having some problems with their plastic cracking. I use a product called Aerospace 303; spray it on all plastic pieces a couple times a year and wipe off. It will help prevent fading, yellowing, cracking, etc. It has some very good UV protectors built into the product. It's expensive, but it works really well. It was developed by Boeing engineers to help in maintaining their aircraft.
Here's a link that gives a better explanation, but you can get this on Amazon, auto parts stores, etc.
https://www.goldeagle.com/product/303-aerospace-protectant
2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed0
- 959 Air Conditioning & Refrigeration
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
