New used Camper
jmazelis
Member Posts: 2
I just purchased a 2015 T@b Max S, which was winterized and
I plan to use it this weekend. Other than the valves next to my Alde 3010
heating system, is there any others that I need to change. I probably
won't use the camper again until August. Do I need to winterize it
again? I was told that there is a drain by the rear stabilizer on the
driver's side. What is this for?
Joel
Only re-winterize if your travels take you to freezing temps or you plan to not use it until next spring.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 919 Introductions
