Table Solution
As others have done, I removed my table and carry a folding TV table if I find the need for one. I often do not even bother with the TV table and just eat out of my lap if I need to eat inside. I think I may have found a better solution. This little table, designed primarily to use with a laptop computer, seems ideal to use as a table for one. It has almost endless size and position adjustments and folds flat for easy storage and transport. And, of course, it can be used for laptops, reading, or any other use for which a small table is needed.
Ordered it tonight and can't wait to try it out. Cost was $57.10 with free shipping. Made of aluminum and comes in pink, purple, black and white.
Larry, I like the looks of that table. I have been using a lapdesk for eating and using my tablet/keyboard. It does double duty as a nightstand at bedtime.
Received the table today. It adjusts to several heights and positions. I can tell already that meals and computer work will be much more comfortable in the future.
It folds flat for storage, and I found that I can store it behind one of the bench cushions.
We rembed the metal stand under our table and installed the pole. We also used an old tv tray top and made a smaller table to use for computer. They both work great.
I agree the stock popup table takes a lot of effort to bring up/down each day for sleeping. Seems like I always bash some of the interior each time or pinch a finger.My current experiment is to use the "stock table" outside the camper and order "leaves" from LG to fill the table "hole" for sleeping. Morning should be much simpler to remove the leaves, they are small and can hide under seat bench. Of course we can still eat inside in the rare event we must eat inside. The stock table is outside and just needs to be brought in. We'll see how this theory holds up.The "leaves" are $30 each and Elsie is figuring out if we need 2 or 3. Will post pics when arrived. Little Guy customer service is great!
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
