So for the second time while dry camping I am in the shower, and water stops flowing. I check water level reads 13%, I add water to the tank and pump runs but no water. I drive to dealer the first time they replace the pump and we are back in up and running. Two weeks later same thing took trailer to dealer, guy in the service department says you are drawing the tank water to low getting an vacuum lock. Is there a level the fresh water tank should not go below? It would seem when you only have 11 gallons to start with you need every drop. We have a three week trip starting next week and will be dry camping a lot of it.
2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn
