Removing Sofa
foxden
Member Posts: 148
I am getting ready to re-cover the sofa back and will be installing the wire storage shelves behind/below the sofa at the same time. Anyone have tips or hints for taking out the sofa back and removing the hinges for re-covering? It may be a very simple task but thought I would see if others who have done this have any suggestions.
2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX
I completely removed the sofa and replaced with a full-time twin bed (a little shorter than normal twim) configuration. Here are my notes on the sofa removal.
1. To remove the sofa back, there are four screws on each side that attached the hinge to the supporting 2x4. Remove the screws. The are also 4 screws on each side that hold the back cusion to the upper part of the hinge. These do not have to be removed to get the sofa back out, but you can remove them if you want to separate the back cushion from the hinges.
The forum thread with photos:
http://tab-rv.vanillaforums.com/discussion/3265/head-bump-guard-and-other-interior-mods#latest
Thanks!2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX0
I found removing the sofa back to be fairly easy - Just unscrew the hinges from the mounting wood beams then lift it up and out. Then remove the hinges from the sofa back itself.
Check out http://tab-rv.vanillacommunity.com/discussion/comment/59347#Comment_59347
Hope this is not too late to be of help.
Reformed tent campers now in Ab T@B - 2016 Outback0 -
@foxden, do you have pics of your handiwork?
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
@Homebodyatheart This is a BIG departure from my usual and has been termed "girly" by a few friends. It is actually much more coral than pink but when I asked a friend if it was likely he would take his buddies out on a fishing or hunting
trip in my T@B he said "nope". Confirmation that it is, indeed, girly. I love it and am very proud because I don't sew. At all. 2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX5 -
Nice job! Tell your buddies: "Bring sunglasses, and git over it!"
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0
- 424 Service/Maintenance & Recall Notices
