Help Mounting Noco Battery Box for the Two Golf Cart Battery Mod
Bert
Member Posts: 87
I'm hoping to mount my new Noco Battery Box on the Outback platform. When I mounted Action Packers there, I cut two holes in the bottom of the Action Packers, then used a large bolt with large fender washers so I could use the holes already in the Outback platform (no new holes to drill).
The Noco battery box has four notches on the outside corners that are for 1/4-inch fasteners. Two of these notches end up above the metal tubing that supports the flat metal plate of the platform.
Can I drill holes in the bottom of the battery box without disturbing its function (one Youtube video shows holes being drilled--for venting??)?
Can I have a metal bolt beneath the case of the Trojan battery? Would I need neoprene foam between the battery and the bolt head?
Note that the battery box has recesses where I will mount the bolt, so I don't think the bolt will be contacting the bottom of the battery, but won't have an easy way to know once the batteries are in.
I am using a board to separate the two batteries and keep them from moving inside the case.
Thanks for help from anyone who understands these matters....
I mounted the same noco box exactly as you suggest- drilled holes in the recessed section of the box and bolted down. No foam required - plenty of clearance between the bolt head and the battery. Works great.
James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback0 -
I did not have any suitable fender washers on hand for the inside of the box so I fabricated some from spare checker plate. Used cross link high density foam to pad between.
2016 Jeep Cherokee & 2017 T@B Outback3 -
Thanks, Hymie. Always nice to know what's worked for someone before drilling holes.1
I used angle iron to mount them to and then large beefy fender washers inside of the box.
@Mr_Mrs_Gnome mounted the box directly to the Outback platform, I believe.
@jkjenn is right. We used some big fender washers and mounted through the holes in the OB platform deck. Sorry, no pics of the inside or under the platform.'17 Outback S - TV 2016 Chevy Colorado in "Colorful Colorado"0
