Glycol for the Alde is now available on Amazon
Verna
Member Posts: 6,876
For those who would rather order the exact same glycol that nüCamp uses in the factory, you can now order it through Amazon (but it is still available through Awesome Elsie in Parts at nüCamp!). Be sure to order this exact name on Amazon, per Marvin in Warranty:
3
Awesome Elsie is such a great nickname for her.
3 -
Thanks Verna!2016 T@B CS-S silver with white trim and WSU themed
Pulled by a silver 2017 Chevy Silverado
Leaves on T@bventures from Spokane, WA
Just a heads up, it seems amazon may have mis-inventoried some of them. I ordered the exact gallon pictured above and they sent the 32oz concentrate instead (had an amazon label with the gallon model number on the back). Amazon fixed it right away for me and sent the right one out.
2016 T@b M@x S Sofitel >- 2017 Subaru Outback 3.65 -
Do you put this in straight out of the container. Doesn't appear to be concentrate. And how do you see where the minimum maximum lines are inside that enclosure. Does anyone have a picture of what it looks like at the proper fill line?0
@Leeh22, Zoom in and you will see the MIN/MAX lines. I believe this was a European model (pink instead of yellow/green glycol That US t@bs are using) but the tank itself and the level markings are the same as mine. The first time I found the tank I marked those lines with a Sharpie (@Verna 's idea) which has made it much easier to find since.
As for whether the glycol shipped/recommended by nucamp is concentrated or not, I will defer to somebody who has recently ordered it. It is in my to-do list right now. I am guessing it says on the bottle though.Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.0 -
http://tab-rv.vanillaforums.com/discussion/4041/alde-glycol
http://tab-rv.vanillaforums.com/discussion/1128/alde-glycol2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0
