Glycol for the Alde is now available on Amazon
For those who would rather order the exact same glycol that nüCamp uses in the factory, you can now order it through Amazon (but it is still available through Awesome Elsie in Parts at nüCamp!). Be sure to order this exact name on Amazon, per Marvin in Warranty:
  • jkjenn
    jkjenn Member Posts: 6,425
    Awesome Elsie is such a great nickname for her. :)
  • 2Cougs
    2Cougs Member Posts: 935
    Thanks Verna!
  • Leeh22
    Leeh22 Member Posts: 30
    Do you put this in straight out of the container.   Doesn't appear to be concentrate.   And how do you see where the minimum maximum lines are inside that enclosure.   Does anyone have a picture of what it looks like at the proper fill line?
  • RollingLagrima
    RollingLagrima Member Posts: 435
    edited September 2017
    @Leeh22, Zoom in and you will see the MIN/MAX lines. I believe this was a European model (pink instead of yellow/green glycol That US t@bs are using) but the tank itself and the level markings are the same as mine. The first time I found the tank I marked those lines with a Sharpie (@Verna 's idea) which has made it much easier to find since.
    As for whether the glycol shipped/recommended by nucamp is concentrated or not, I will defer to somebody who has recently ordered it. It is in my to-do list right now. I am guessing it says on the bottle though.
  • TabberJohn
    TabberJohn Member Posts: 588
