There isn't an additional filter between the fresh water tank and the pump filter. If I was experiencing this scenario I would probably take an air compressor and try blowing out the line from the pump back into the FW tank. It sounds like there is debris clogging this line.,LauraRey said:
At this point, is there anything else I can do short of taking off the undercover and removing the fresh water tank?
Does anyone know if there is a filter or screen between the tank and the line running up to the filter and pump? If so, where is it located?
Thanks,
Laura
Good question! I'd probably try opening up the gray drain valve behind the step, blowing the water out from the pump intake hose, back through the FW tank as that's about all you can do, minus removing the FW tank which would be a difficult and tedious project at best. I have seen junk in the screen and cannot verify it is a factory issue or a result of the tank manufacturing process. This is obviously of concern to factory reps and I've discussed it with them and they are taking precautions and creating an awareness on their end as well.Twojgrams said:@Michigan_Mike and @LauraRey, then what? If debris is blown back into the FW tank and if the drain isn't located on the bottom of the tank, even draining the tank would not necessarily get rid of the debris. Unless the borescope was also equipped with a vacuum, how do you get rid of the debris without removing the tank?
@dsatwork...do you want to chime in here with our experience?LauraRey said:Hi Folks,
I've spent my day troubleshooting the lack of water pressure in the T@B. It was acting like the filter was plugged: it would have great pressure for about 5-10 seconds, then fade. I took off the filter and cleaned it out. Yes, there was some debris in it. After cleaning it, I put it back on, topped off the fresh water tank, and started up the pump. Same thing happened. (I explained to the pump that this was inappropriate behaviour at this point.)
Then, after chatting with Jill and Dale (thanks to them both), we disconnected the input line and ran a hose from a full bucket of water to the pump. Switched on the pump, and Voila! The pump was fine.
We also inserted a valve between the water filter and hose that allows us to connect a hose to prime the pump, if needed. We primed the system. Still didn't work.
So, that leaves an issue between the fresh water tank and the pump. As Dale mentioned, it is most likely a plug of some sort. Having never investigated this before, we ran a borescope from both the inside (top down) and from the fresh water intake, in. Unfortunately, the run was longer than our scope cable. So, it didn't yield much.
Thanks,
Laura
In the 2017 the air vent sputters and spits the for the entire fill. You really need a small adapter hose to get it inside the neck of the fill spout, to keep water for entering the blow hole.ChanW said:@Ratkity brings up an important point re:the vent hole in the filler neck on the earlier LG Tab. The actual FW tank vent on these Tabs also is the overflow for the FW tank, and exits out the front center bottom of the Tab.
On our FW filler fitting, the 'vent' was also just an open hole, with no vent hose connected in the back of the fitting. Problem is, with the hole open, while filling the FW tank with a garden hose via that filler neck, the water tends to go into that hole, ending up inside the wall behind the toilet.
I plugged that hole in ours with some goop.
@Ratkity, you mention a plug of dirt being forced out of your vent/overflow tube. I wonder if it was actually a plug from a mud-dauber wasp? We've put screens on hose ends and all other openings on the Tab (fridge vents, Alde exhaust, etc) that would attract these creative creatures. Also don't want those dang Asian lady-beetles to make a winter home - both are problems here in the Northeast.
Thanks @Michigan_Mike for discussing this issue with them. They make such an exceptional product that hopefully raising awareness may prevent this in the future.This is obviously of concern to factory reps and I've discussed it with them and they are taking precautions and creating an awareness on their end as well.
