T@B Visor XL
Can you open the door all the way with the XL visor, and if not, is that a problem? We like to use the screen and have the door full open.
Mickey & Terri
2016 Max S
Kalamazoo Michigan
  • Verna
    Verna Member Posts: 6,876
    No, you cannot open the door all of the way with the XL visor. It opens about 60* or so. I keep the door held open with a loose fitting bungee cord attached to the front handle and it gives me plenty of air through the screen.
  • Dalehelman
    This is my hack for holding the door  partially open. By keeping the door farther from wall it also allows better air  circulation for the refrigerator vent. I use it with or without the visor.
    1. Hash  T@B Fun
  • ClaudeA
    ClaudeA Member Posts: 54
    Another smart hack. I will look in to it when I get the visor, some day.
    2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
    Ottawa, Ontario
  • MisterZ
    MisterZ Member Posts: 1
    Clever mod you have there.  What is the long piece made from?
  • TerryV6
    TerryV6 Member Posts: 1,101
    The clip on the door. -  how is that secured?  Command straps don't seem strong enough..  good idea btw...
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • Dalehelman
    A piece of  Square aluminum bar stock I picked up at  Home Depot
    1. Hash  T@B Fun
  • Dalehelman
    I used 3M red back double sided tape. Command strips would work fine IMHO
    1. Hash  T@B Fun
  • Tabaz
    Tabaz Member Posts: 2,420
    This is a great mod. But it doesn't have to be too complicated. I couldn't find my metal rod once and had to use a coat hanger instead. Worked just fine if there are no winds. I also just toss the metal rod into a tub instead of securing it to the door itself.
    2016 Outback 320
  • Dalehelman
    At my age I tend to forget where I put things. The rod was left over from another project.
    1. Hash  T@B Fun
  • TerryV6
    Thanks...
    T@bbey  Road
    Appleton,  WI
  • TerryV6
    Hmmm....  I would think the coat hanger might be nice as the hole drilled would be smaller and the plastic piece would lose less strength integrity...
    T@bbey  Road
    Appleton,  WI
