T@B Visor XL
mandt
Member Posts: 158
Can you open the door all the way with the XL visor, and if not, is that a problem? We like to use the screen and have the door full open.
Mickey & Terri
2016 Max S
Kalamazoo Michigan
2016 Max S
Kalamazoo Michigan
No, you cannot open the door all of the way with the XL visor. It opens about 60* or so. I keep the door held open with a loose fitting bungee cord attached to the front handle and it gives me plenty of air through the screen.Verna, Columbus, IN
This is my hack for holding the door partially open. By keeping the door farther from wall it also allows better air circulation for the refrigerator vent. I use it with or without the visor. - Hash T@B Fun
Another smart hack. I will look in to it when I get the visor, some day.2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
Ottawa, Ontario -
Clever mod you have there. What is the long piece made from?
The clip on the door. - how is that secured? Command straps don't seem strong enough.. good idea btw...Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI -
TerryV6 said:The clip on the door. - how is that secured? Command straps don't seem strong enough.. good idea btw...
I used 3M red back double sided tape. Command strips would work fine IMHO- Hash T@B Fun
This is a great mod. But it doesn't have to be too complicated. I couldn't find my metal rod once and had to use a coat hanger instead. Worked just fine if there are no winds. I also just toss the metal rod into a tub instead of securing it to the door itself.2016 Outback 320
At my age I tend to forget where I put things. The rod was left over from another project.Tabaz said:This is a great mod. But it doesn't have to be too complicated. I couldn't find my metal rod once and had to use a coat hanger instead. Worked just fine if there are no winds. I also just toss the metal rod into a tub instead of securing it to the door itself.- Hash T@B Fun
Thanks...Dalehelman said:TerryV6 said:The clip on the door. - how is that secured? Command straps don't seem strong enough.. good idea btw...
I used 3M red back double sided tape. Command strips would work fine IMHOTerry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
Hmmm.... I would think the coat hanger might be nice as the hole drilled would be smaller and the plastic piece would lose less strength integrity...Dalehelman said:
At my age I tend to forget where I put things. The rod was left over from another project.Tabaz said:This is a great mod. But it doesn't have to be too complicated. I couldn't find my metal rod once and had to use a coat hanger instead. Worked just fine if there are no winds. I also just toss the metal rod into a tub instead of securing it to the door itself.Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
