T@B Visor XL
Can you open the door all the way with the XL visor, and if not, is that a problem? We like to use the screen and have the door full open.
Mickey & Terri
2016 Max S
Kalamazoo Michigan
    No, you cannot open the door all of the way with the XL visor. It opens about 60* or so. I keep the door held open with a loose fitting bungee cord attached to the front handle and it gives me plenty of air through the screen.
    This is my hack for holding the door  partially open. By keeping the door farther from wall it also allows better air  circulation for the refrigerator vent. I use it with or without the visor.
    1. Hash  T@B Fun
    ClaudeAClaudeA Member Posts: 54
    Another smart hack. I will look in to it when I get the visor, some day.
    2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
    Ottawa, Ontario
    MisterZMisterZ Member Posts: 1
    Clever mod you have there.  What is the long piece made from?
    TerryV6TerryV6 Member Posts: 1,092
    The clip on the door. -  how is that secured?  Command straps don't seem strong enough..  good idea btw...
    Terry & Jody...  2016 Dodge Ram 1500
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
    A piece of  Square aluminum bar stock I picked up at  Home Depot
    1. Hash  T@B Fun
    I used 3M red back double sided tape. Command strips would work fine IMHO
    1. Hash  T@B Fun
    Tabaz Tabaz Member Posts: 2,357
    This is a great mod. But it doesn't have to be too complicated. I couldn't find my metal rod once and had to use a coat hanger instead. Worked just fine if there are no winds. I also just toss the metal rod into a tub instead of securing it to the door itself.
    At my age I tend to forget where I put things. The rod was left over from another project.
    1. Hash  T@B Fun
    Thanks...
    T@bbey  Road
    Appleton,  WI
    Hmmm....  I would think the coat hanger might be nice as the hole drilled would be smaller and the plastic piece would lose less strength integrity...
    T@bbey  Road
    Appleton,  WI
