Troubleshooting 120v Outlet/Alde Power Issue
jkjenn
Member Posts: 6,425
2015 T@b S Maxx
I noticed tonight....2 nights before vacation that 120v power is not working on my rear GFCI outlets, the front galley outlets, nor the Alde on shore power. The dedicated A/C outlet works.
I reset the GFCI outlet and tge breakers at the panel, as well as checked all fuses. No errors on the Progressive EMS.
A friend is coming to help me test the circuit.
Any advice would be appreciated.
Crisis averted: did not press GFCI hard enough, lol.
3 -
Glad you got it solved, but I'm still suspicious. While a tripped GFCI would kill power to all the cabin outlets, the Alde--like the A/C--should be on a different circuit and not be affected. Might be a different problem lurking there...
You know, not 100% sure the Alde wasnt working. I just didnt hear that rumble thatbyou usually get when it kicks on. Does that sound happen on shore power or just LP?ScottG said:Glad you got it solved, but I'm still suspicious. While a tripped GFCI would kill power to all the cabin outlets, the Alde--like the A/C--should be on a different circuit and not be affected. Might be a different problem lurking there...
It was too hot and humid to leave the heat on.
