Cutting hole in T@B wall to install city water hookup
I'm wondering the best way to cut a hole in the (aluminium/board/insulation) side wall of a 2004 T@B to install city water hook-up.  Also, any recommendations for the water fitting?  I will put a "T" in the water line on the tap side of the water line.  I appreciate any input.
2004 T@B
Qualicum Beach, BC
  • jcfaber1
    jcfaber1 Member Posts: 318
    Chris, I went about it differently in our 2007.  I added a 10 gallon tank underneath.  In front of the tongue box, I added a wooden box where the gravity and city water fill is located.  From there, the water lines go to a bypass valve prior to entering the t@b.  The valve is in my tongue box.  From there it enters the tab underneath through the floor.  It is a bit more involved than described here as I have added a water pump and heater.
    John
    2007 T@B
    Rockford, IL
  • ChrisJ
    ChrisJ Member Posts: 12
    Thanks for the input John.  I'm not considering a HW heater at this time and already have a 5 Gal. tank used with the pump, which is adequate for our needs.  Any thoughts on best way to cut a hole in the side?  Think a standard hole saw would work?
    Chris
    2004 T@B
    Qualicum Beach, BC
  • jcfaber1
    Yes a standard hole saw should work.  The finer teeth the better
    2007 T@B
    Rockford, IL
  • Michigan_Mike
    I would consider using some painters tape across the area you plan to cut and as JCFaber noted, use a hole saw bit with fine teeth.  Hopefully there are no hidden frame components in the cut area.
  • ChrisJ
    Thanks Mike.  Good call to watch for the frame... and John.
    2004 T@B
    Qualicum Beach, BC
