2006 Tab Clamshell Surge Brake Adjustment?
I've a 2006 Tab Clamshell. How do I adjust the brakes so that they engage properly when moving/braking and stay disengaged when backing up? There does not appear to  be a brake lockout mechanism.
  • rfuss928
    rfuss928 Member Posts: 1,197
    edited September 2017
    Brake operation and adjustment .pdf files attached.
    Make sure the coupling head is well greased and moves in smoothly with some effort and then extends on its own.  There are two grease fittings underneath - one on the slide and another on the pivot.
    Moderators  -  I've attached these .pdf files several times before.  Is there a "files" area where this kind of info can be stored and accessed?
  • ericnliz
    ericnliz Member Posts: 4,437
    @rfuss928, You'll need the "magic wand" for that one! ;) ...... @Verna? =)
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
