Trying to get hot water function in a 2018 T@B CS S
moonshadow
Member Posts: 2
The hot water coming through the faucets doesn't last more than 30 seconds. What are we doing wrong?
@moonshadow, I had the same problem...you'll need to adjust your mixing valve. Mine was set too low, and like you, only lasted for a few seconds of hot water. You can also set the Alde hotter for hot water using the shower display button to the #2 setting. Mine is diiferent than yours, so if someone with the same set-up could post a picture, it would be helpful..Thanks.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf -
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az -
Moonshadow, be very careful when you do this because if you loosen the screw too much you will get a bath!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks, I will try it. I was afraid to loosen the screw but will now with others saying it is okay to do.
I did it a few months ago after reading the information here. Go slow on the adjusting knob and change it in little increments and then test after each adjustment. It doesn't need to move very much.
My valve on a 2018 was a little different: it sits facing up. So the instructions to "move the knob out to the side" confused me a bit until I realized the difference.
Towed by 2014 Touareg TDi -
This worked for me! Loosened the screw, pulled out the knob to disengage it, rotated clockwise reset the knob, and turned more counter-clockwise. Hot water! Thanks!RollingBnB said:
T@B 400 | F150 | Washington State -
@Haloo, Glad it worked for you! Thanks for letting us know what solved the issue.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf
- 916 Introductions
- 72 Teardrop Groups & Links
