Is there a power disconnect on the 2018 T@B?
  • brookingsbrookings Member Posts: 39
    Does anyone know if the 2018 tab has a way to disconnect power.
    Do you mean a battery cut-off switch?  Can you update your signature line so we know the year and model of your TaB and tow vehicle?
  • IslandJoIslandJo Member Posts: 60
    My 2018 came with a cutoff switch. I think it is standard now. It's the red knob in the front tub behind the battery.
    2018 T@B CS-S on an Outback axle
    2017 Toyota Tacoma with tow package
    Pacific Northwest
  • rcuomorcuomo Member Posts: 321
    Our 2018 T@B built in April has the battery cutoff switch in the front tub. As IslandJo mentioned, it is now standard equipment.
    Huntington LI
  • MarcelineMarceline Member Posts: 1,745
    boo said:
    The only way to completely kill the power to the T&B is to remove the power cord and disconnect the battery cables.
    Most T&B owners install a battery cut off switch. It is an easy and inexpensive mod. Cut off switches can be purchased at auto parts stores.
    If you are not familiar with them, go to YouTube and see "installing a battery cut off switch".
    For those of us without a cutoff switch pulling the fuse from the line connecting the battery to the trailer is an easier solution that disconnecting the battery cables.
    San Francisco Bay Area
    2013 CS-S us@gi
