Ran an extension cord out to my T@B today to do my monthly battery charge/maintenance. I checked the battery's charge before plugging in, and it was at 12.6V. I then connected to shore power, and the battery still checked at 12.6V. This is a bit unusual because when the T@B is connected to shore power, the battery usually checks at about 13.7V. As I was standing there scratching my head (about 30 seconds or so had elapsed) I heard a beep, and the voltage immediately jumped to 13.7V. I assume the beep came from the converter.
Is there normally a delay in the converter when it is connected to shore power, or is something else going on?
I have noticed slight delays, but just a few seconds. That seems odd.
Well, excuse the dummy (that would be me). I decided to read the manual again for the surge protector. It clearly states, "The EMS has a 136-second time delay before you will receive power into your RV." So, if you have a surge protector from Progressive Industries, there will be a delay of 2:16 from the time you plug it in until you have shore power to the trailer. I have plugged this thing in every time I've stopped for the night (several times), and have never noticed this delay before. Looks like I have exposed my ignorance for the benefit of others' knowledge. You're welcome.
This is the model I have.
It was the first major purchase I made right after I got the T@B, knowing how unstable some power sources can be, especially in some of the older parks.
As for the long cord, there have been times when that would have certainly come in handy. There have been a couple of configurations of pedestals that made it very difficult to use the surge suppressor. Once I had to plug it in upside down. Those pedestals are certainly not standardized, and I have found a couple that were just sort of cobbled together.
That little "on/off" action in your neighborhood circuit during storms, etc. is actually built in reclosing capability in the area's substation equipment or out on the line. If the circuit senses a fault (e.g., a lightning strike, limb laying on the primary, animal short-circuited on a transformer, etc.) out on the line strong enough to operate the circuit recloser device it will trip once, then reclose again to either clear the problem from the circuit or trip again. Normally the circuit will trip three times before going to lockout (requiring a line patrol, finding the problem and restoring power), depending on what the problem is out on a line.ChanW said:That delay that Progressive incorporates into their protectors is to give things like air conditioners and AC fridges time to 'reset' if there's unsteady power.
In our neighborhood, when the power goes down, it often will come back on only momentarily, before it comes back on steady. That on-off-on stuff is hard on these motor/compressor appliances, and on electronics.
