Alde heater not giving enough heat
      On my 2015 t@b I was getting some heat but not enough to warm up cabin to be comfortable.     Located under back self behind head board is a container to fill with a product called glycol.   self removed by taken out two screws.   Mine was filled at minimum level.   after topping off, cabin became very warm.    Product purchased at RV store and its an antifreeze that's light yellow called glycol ?     Hope this helps someone.   Factory must have under filled it.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
  • DurangoTaB
    DurangoTaB Member Posts: 754
    Search on “glycol”and you’ll get LOTS of good help!
    J.D. & Sue
  • ericnliz
    ericnliz Member Posts: 4,437
    @deputydog, You're on the right track, as I believe the recommended "fill" is about 1/4" above the minimum line. You'll need to bear in mind that once the glychol heats up, it will expand, so be careful not to fill the reservoir too full. ;)
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
  • WrongWayRex
    WrongWayRex Member Posts: 7
    Some of these systems need to be burped, sometimes a couple of hours of run time will push the air bubbles out (burping) and then the fluid level can be brought up to correct levels. Normal in a lot of different type of coolant associated items.
    Camp-Inn
  • jim
    jim Member Posts: 1
    what type glychol do I add to my Alde 3010 system?
    Century Chemical TF-1 Transfer fluid available on Amazon.
  • AirBoss
    AirBoss Member Posts: 740
    @Sharon_is_SAM
    Same for 3020 Alde? Not concerned now as last weekend was maiden voyage but for future reference. Many thanks!
    San Diego, CA
    www.airbossone.com
    @AirBoss, yes, same glycol.
  • AirBoss
    Danke Mucho!
    San Diego, CA
    www.airbossone.com
