Installing a magnetic knife holder
Hi folks-  I recently bought a 2014 S TAB. Id like to install a knife rack on the wall to the right of the stove. Am I going to hit any wiring if I screw into that wall?  Thanks!
—Nancy
  • dragonsdofly
    @Nancyp21, do not screw anything into the walls of your trailer. They are a composite (foam) sandwich and only about an inch thick. Almost everyone makes use of the 3M removable strips and hangers in some creative fashion. Putting small screws into the wood valances or cabinets is possible, and sometimes done.
  • jkjenn
    jkjenn Member Posts: 6,425
    —Nancy
    Hi Nancy and congrats!
    Trailer walls are not like building walls in that you cannot expect to drill into them and have that be a solid hold because there is foam behind the wall, not wood or foam. Most people will use a heavy duty 3m adhesive and stick to the walls, unless you know there is wood or metal behind it.
  • dragonsdofly
    @Nancyp21, I also see this is your first post, so welcome to the forum, to the t@b family and congratulations on your trailer! If you have a bit of time, read the modification category, or do a search with key words like "putting screws in walls". You'll find lots of threads about the subject, some even include pics of wall cross sections, so you can see how they're made. Learning about your t@b is part if the adventure. Good luck and happy t@bbing!
    pthomas745 Administrator, Moderator Posts: 4,685
  • Nancyp21
    Nancyp21 Member Posts: 2
    Thank you all!!!
  • Homebodyatheart
    I’ve had good luck with heavy duty velcro when the Command strips won’t hold. Used it on my paper towel holder and my “charging station “ on the wall to the left of the sink.(320S) Good luck!
