I'm considering changing out the LP gas/battery cover for a real aluminum diamond-plate tool box for storage on the tongue. I've seen pictures of T@Bs with everything from small boxes (i.e. not much bigger than what's there now) boxes to 60" wide by 18" high by 20" deep: 13 cu. ft of locked storage!
Does a box that's 5' wide interfere with the turning radius? I'd hate to find out after I got it that it crunches into the tow vehicle on tight backing turns? Anybody with a big tongue box had problems? Or positive experience?
And how much weight can be added to the tongue? I could use some additional weight on the tongue but I could also fill a huge box with a generator, extra gas, extra water and a bunch of tools and easily over do it.
Any thoughts?
Mitch
Mitch & Cheryl; the Paddlebumz
2015 T@B CS - silver and black..."W@ltzin' M@tilda"
0 ·
Your 2001 Toyota Tundra looks to be rated at just over 7000 lbs. GVWR so you should probably not have any issues towing your T@B and with added gear. Tongue weight should be 10% to 15% of the overall trailer weight. Here is some good information from ETrailer that will give you some basics for tongue weight: Determining Tongue Weight
that's what I was afraid of. I'm not wedded to the 5' box; I have just seen some T@Bs with that size box and wondered about the turning. I do want something bigger, but I guess a 5' box is a bit of overkill.
Mitch
And it does not affect my turning radius in my 2012 Honda Ridgeline. From the tongue to the edge of the box, I only have 29-1/2" and it is enough clearance. No issues with a complete U-turn.
Odessa, Fl.
Leadville Colorado
