Battery hookup
Seaduster
Member Posts: 147
I had a neighbor remove my battery for the winter. I had asked him to take a picture of the setup before removing the battery, but he forgot. Now I'm confused as I see four cables to attach to the battery. Do I connect BOTH of the white cables to the negative post and the red AND blue cables to the positive post?
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
If you have the solar port on the propane tub, you should have a red and white cable extending from that port to the inside of the tub. The red is positive and the white is negative. The blue cable probably holds a plastic fuse box and the cable may be spliced into a red cable - that goes to the positive terminal of the battery. The other white cable goes on the negative terminal of the battery. Here is a picture of mine. Ignore the thin, red cable as it supplies the charge to an optional battery monitor. Make sure you put the negative cable on last.
Forgot to include a picture of the cables...
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
