We recently purchased a 2017 T@B S Max and are slowly learning the ropes. It is stock for all electrical connections and battery. When we picked the trailer up the battery meter was reading 12.6-7 off of shore power and 13.6 on shore power. We have had it parked at our house for several weeks since picking it up. On shore power for about a week, then off for about a week with the battery switched off in the front storage shell.
Now when off of shore power the battery meter is reading 18.5 volts, when I attach shore power it jumps to 19.6 volts. I went thru the meter manual and cannot find an explanation for this. Everything in the camper works as if the battery is fully charged.
Any ideas?
Rich Bradley 2017 T@B S Max Northern Illinois
0 ·
Battery is essentially new and as it was on shore power for a week with no electrical draw it should be fully charged and at 12.7V.
If your SeeLevel meter has been working up to this point, if it were me, I would tag each wire as to what side of the battery it belongs on (+ or -, positive or negative), and I would remove the wiring and remove the battery from the T@B. Why? The voltage is too high and I would rather err on the side of caution until you can check the voltage with a multimeter.
If the multimeter agrees with your SeeLevel, something is wrong and you need to correct the problem.
My batteries have never gone above 14.7V and that is either bulk or absorption mode (someone will put the correct mode here), which is normal. 19.6V is not normal.
2016 Jeep Cherokee & 2017 T@B Outback
aka BirdieJane towed by Quinn
Now for the rest of the story......a new T@B owner a few years ago (I forget their names, and can’t remember for the life of me!) had a new battery, less than 6 months old, that went bad. They were on their first longer trip and the battery actually caught on fire in their front tub. They called AAA and were on their way soon with a new battery. That is why I was worried about your high reading.
https://tab-rv.vanillacommunity.com/discussion/comment/692#Comment_692
and the damage that was done:
https://tab-rv.vanillacommunity.com/discussion/comment/682#Comment_682
