R-Pod PahaQue Visor???
Gidget
Member Posts: 64
Does anyone know if the visor that fits the R-Pod will fit the 320s? It's quite a bit cheaper at CampingWorld plus i have a $50 off coupon! So, I'm considering buying it but am curious if anyone else has tried it. Holla!
Look out open road, here we come!!! Me, my Gracie May, a 2YO Beaweenie; half Beagle, half Dachshund, Dash, the 2015 Kia Sorento LX V6, Gidget, the 2018 nüCamp 320s!
It is made for a 14 mm (.563 inch) keder rail. Tab uses a 9.5 mm (3/8th inch or .375 inch) keder rail. You would need to remive the keder rope and replace with a smaller keder rope.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Rpods are also quite a bit taller than the Tabs so that might be an issue. I do love the cabana dome for its versatility though!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
Also, be aware, if you try to make your own Tarp Trackers - those devices that slude into your rail that attach to grommeted tarps, the screws will get in the way, so you will need to size down.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Myself I got the Keder single flag 8.5mm x 30'. Enough to do both sides for my 400. For the first use, I used a 10'x12' mesh tarp so the wind would not be a major concern and adjustable poles with guy lines for the end, I had the wife sew some Para-Cord which matched up with the 12' side grommets of the tarp on a 13' length of Keder Flap.
https://www.amazon.com/Keder-8-5mm-Single-Standard-White/dp/B00P85SFYK/ref=sr_1_1?ie=UTF8&qid=1531059559&sr=8-1&keywords=Keder+-+8.5mm+(5/16")+Single+Flap,+Standard,+White+-+30+Feet
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
Note on the above camp, NFS campground, $5 ($2.50) a day, with outhouse @ 8000' on "A" Yellowstone Creek just south of Kings Peak in Utah, 9 miles of dirt road. Stay there for 4 nights (Thur-Mon), not a single other camper, just some fly fishing visitors on the lake below. Using 1 gallon of propane and hardly any water from the T@B but did go thru 6 gallons of drinking water. Gray/black water were about 1/3 full when we left, nattery lasted without any signs of use really, appeared to be fully charge by the end of the day and was @ 12.4vdc in the mornings.
Utah Driven
5 -
Can you sew the mesh tarp (shade cloth) to the keder flap? You would not need to use the grommets, para-cord, etc.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Sure can
(@Sam)
There are different flag size widths available also.
Note the 7 or 7.5mm is too small of Keder, but 8.5mm worked great. I learned the hard way, LOL
In my case, I wanted the mesh tarp, but easily changed out to a more water resistance cover if needed for a wet camp vs a sunny or windy one. Why I went for the tie system. The Keder flag really doesn't fold up as tight as the tarp and did not want to carry more than what was needed.
Utah Driven
Good thinking. Reuse your keder rope. DH just completed our shade cloth tarp. Will post info soon.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Bummer and thank you for helping me avert a regrettable purchase.SAM said:It is made for a 14 mm (.563 inch) keder rail. Tab uses a 9.5 mm (3/8th inch or .375 inch) keder rail. You would need to remive the keder rope and replace with a smaller keder rope.
