Outside Shower Hose
DavidLM
Member Posts: 24
The outside shower hose in my T@B 320 seems very short. It only extends a couple of feet at most. Is it meant to be this way, or could it be jammed inside? I’m reluctant to pull on it too much for fear of breaking it. Advice?
If you pull up the cushion where the Aldea is you should be able to check if it is stuck
But I don’t think it is a very long hose -
@DavidLM, once you discover it’s length, careful not to extend it too far. Check out what Ferd had to say in the thread linked below.
https://tab-rv.vanillacommunity.com/discussion/7053/very-limited-water-pressure-from-outdoor-shower
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio -
Thank you lino!
Thank you Sharon_is_SAM!
- 919 Introductions
