T@B 400 Fridge Freezer Icing Over and Overall Performance
Just returned from another shake down trip with my new T@B 400  I have noticed that the freezer door is slightly bowed out and does not quite latch a leaves a 1/8 inch gap where it is suppose to latch,  and with the fridge set at 3 the freezer ices up and bairly keeps ice cream from total melting.  Also the fridge turns on every 10 minutes with an ambient temperature of 70 degrees and seems to drain the battery in two days with nothing else on.  Is this normal?  Any feedback would be appreciated.
  • jkjenn
    jkjenn Member Posts: 6,423
    The fridge is pro ably kicking on because of your gap. Adjusting the door on a fridge is not an unusual adjustment. Your dealer should be able to do that for you if you are uncomfortable doing it yourself. Test the performance again after it is fixed.
