2018 CS-S Alde Mixer Valve Leaking
Barry
Member Posts: 11
Has anyone else had water leaking from the alde mixer valve? My cold water input - and occasionally the hot water, too - is dripping and I'm considering adding rubber hose washers to the connections but don't want to mess things up further. Thanks!
Here are a couple threads that showed up when I searched mixer valve. Sometimes the mixers are defective, sometimes the coupler needs to be changed.
https://tab-rv.vanillacommunity.com/discussion/6811/need-help-mixing-valve-leaking
https://tab-rv.vanillacommunity.com/discussion/comment/79694#Comment_79694
- 919 Introductions
